Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine oil cooler
Old 02-15-2013, 02:47 PM
jeepers creepers jeepers creepers is offline
Originally Posted by cobalt327 View Post
Unless you're adding the vacuum advance in, 45 degrees BTDC is way too much timing.
Be sure the timing tab and damper line are accurately showing TDC- which may not be the case.
Yes Cobalt, vacuum advance was included in the 45, i have a large trans cooler, i thought was too big but transmission is running within right temps, engine is on a Jeep so with under load i meant uphill snow driving like a did yesterday, snow was pretty deep and partially frozen so vehicle needs a lot of power to drive through, also i have the stock temp gauge wich just gives you an idea of the temp because there are no numbers on it but just C/H, i mesured with an infrared gun while the gauge pointer was about in between of C and H and temp was close to 205 F.
Temp sender is on the cylinder head, pass side, i guess that was the stock spot for it even if i have alu heads.
