Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine oil cooler
Old 02-15-2013, 05:53 PM
ap72 ap72 is offline
Banned
Why would you think there would be any added wear?
Also, if you're running an oil cooler be sure to run a thermostat for it, too cold of oil is worse than too hot.
Fix your fans, then fix your oil pressure, 7psi at idle is pretty damn low.
