Engine oil cooler orientation - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2005, 02:32 PM
Neophyte's Avatar
I'm not superstitious
Last journal entry: Release catch for trunk lid pt.5
The attached pic shows the engine oil cooler I'm gonna use on my car. My question is : Can I install it with the fittings at the bottom or will I not get correct circulation? The big thing is that it will make for a much easier and neater installation.
Old 04-10-2005, 03:21 PM
302 Z28's Avatar
It is a pressurized system , it will not matter as far as oil flow. Just be sure that it has good airflow through it. The factory oil cooler on the wife's 04 Tahoe is installed exactly as you describe.
Vince
Old 04-10-2005, 03:44 PM
Neophyte's Avatar
Thanks Vince, glad to hear that. By doing that I can position it so that the elbows point backwards to the engine just below the radiator. Otherwise I would have had to battle with routing the pipes around the radiator to get them to the top of the cooler.
Airflow won't be a problem as the direct airstream through the grille will hit the cooler.
Jacques
Old 04-10-2005, 04:14 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
oil cooler
Try to mount the cooler away from the rad. Connect it to the rad support. If you tie wrap it directly to the rad, you will lose some cooling and get heat transfer when you shut the motor off.
Old 04-10-2005, 10:36 PM
Neophyte's Avatar
That makes sense. Thanks, will remember to do that.
oil change- step by step instructions for women and men Fireball Hotrodders' Lounge 38 08-30-2008 08:39 AM
Rear of engine oil leak 350 western star Engine 5 07-13-2004 04:32 AM
Engine Oil Cooler Full Throttle Engine 25 12-17-2003 02:41 PM
how to prepare a block blndweasel Engine 14 08-15-2003 01:28 PM
Should I change my oil? 48Man Engine 2 01-29-2003 08:28 AM
