-   -   Engine oil plugs (http://www.hotrodders.com/forum/engine-oil-plugs-224069.html)
jdoneff 09-16-2012 01:57 PM
Engine oil plugs
The oil plug under the rear main cap, how deep do you install the plug in the oil passage. SBC engine. One of your hot rod how to books had an article on it in the past, with detailed instructions. Thank you
BOBCRMAN@aol.com 09-16-2012 03:15 PM
Just deep enuf to clear the back of the bearing shell.
jdoneff 09-16-2012 04:49 PM
The plug goes into the block not the cap and I need to know how deep into the block oil passage the plug goes.
machine shop tom 09-16-2012 05:41 PM
NO. SEE BELOW>
tom
machine shop tom 09-16-2012 05:44 PM
Look into the passage. Just past the large hole in the side there is a step. Below that is another step. Install the plug so the top is just past the first step.
Personally I think you posted this in the correct forum (engine) to start with because it is an engine-specific question.
tom
cobalt327 09-17-2012 09:03 AM
Full details HERE.
Good luck.
alkey 09-17-2012 06:46 PM
engine oil plug
thanks Cobalt very good information.
