Engine oil plugs - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2012, 02:57 PM
Engine oil plugs
The oil plug under the rear main cap, how deep do you install the plug in the oil passage. SBC engine. One of your hot rod how to books had an article on it in the past, with detailed instructions. Thank you
Old 09-16-2012, 04:15 PM
BOBCRMAN@aol.com's Avatar
Just deep enuf to clear the back of the bearing shell.
Old 09-16-2012, 05:49 PM
The plug goes into the block not the cap and I need to know how deep into the block oil passage the plug goes.
Old 09-16-2012, 06:41 PM
King of my Man-cave.
NO. SEE BELOW>
tom
Old 09-16-2012, 06:44 PM
Look into the passage. Just past the large hole in the side there is a step. Below that is another step. Install the plug so the top is just past the first step.
Personally I think you posted this in the correct forum (engine) to start with because it is an engine-specific question.
tom
Old 09-17-2012, 10:03 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Full details HERE.
Good luck.
Old 09-17-2012, 07:46 PM
engine oil plug
thanks Cobalt very good information.
oil on spark plugs of new engine BlenderHead Engine 2 10-25-2010 05:16 AM
oil galley plugs 63,68,70 muscle Engine 2 02-04-2009 06:21 PM
Oil on plugs, What do I check for? eric32 Engine 7 07-16-2008 06:57 PM
plugs wet with oil??? bucketboy Engine 4 12-16-2005 10:45 AM
Oil on 2 plugs Fragzem Engine 9 10-01-2004 10:34 AM
