Engine oil.....ZINC - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2007, 05:17 PM
solidaxel's Avatar
Last journal entry: Project garage complete!
Engine oil.....ZINC
Is anyone else in the Hot Rod field concerned about the lack of Zinc in motor oil!!
I read that it has been reduced from 2200ppm down to 4-600ppm, is this going to affect things like cams and flat tappet lifters!!
What are we to use in our older engines??
Old 06-29-2007, 05:46 PM
Ambassador of 'Pane's Avatar
Envirominded hotrodder
Last journal entry: Stupid broken leg
That's a legitimate concern and we've beat that horse a couple times. You can get racing only oil, diesel oil (for a while anyways) or add a little cam conditioner to your regular oil.
Oil is killing our cars!
Cam break-in and zinc
oil is failing cams? no zinc phosphate ?
Article on Oil, Wiped Lobes
Old 06-29-2007, 06:33 PM
solidaxel's Avatar
Very interesting read. Thanks for the info,
I still don't know which oil or additive i will be using in my fleet, all 7 of them, but in the 2000 Jag I will be using the Castrol Syntec.
I guess ignorance is bliss!!!
Thanks for the reads
Old 06-29-2007, 06:42 PM
No problem, you should have seen me on the IFSJA.org forum after I found out about ZDDP. I was installing my third cam for a single rebuild because everyone I knew that was using the first two cams I installed had them fail. My reaction was right out of Chicken Little! "Your cams are failing! your cams are failing!" lol!
Old 06-29-2007, 09:42 PM
302 Z28's Avatar
A can of GM Engine Oil Supplement.
Vince
Chevy 6.5 Diesel has no oil pressure again!!! dorksrock Engine 12 09-02-2012 09:51 PM
Synthetic Motor Oil In 454 Rebuild leejoy Engine 36 11-20-2006 03:34 PM
Engine never the same after a Fram oil filter JamesRS Engine 18 05-02-2005 11:27 AM
Oil pressure loss SB Chevy Finmike Engine 30 06-12-2004 11:27 AM
Should I change my oil? 48Man Engine 2 01-29-2003 08:28 AM
