engine overheating - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2006, 10:56 AM
engine overheating
my son has a 1989 jeep cherokee laredo. we have replaced radiator, waterpump, and thermostat. she still is getting hot, dont think electric fan is kicking on . how can we know for sure?
Old 09-18-2006, 11:01 AM
Have you tried letting it idle and watching the fan?
Old 09-18-2006, 11:15 AM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
First, if it has air conditioning, turn it on, it should make the cooling fan come on. If it does you know the fan itself works, then let it idle and see if the fan comes on. Coolant temp needs to be at 190* or higher to activate the cooling fan. Also look at the cooling fan relay (left hand side of engine compartment) if these steps do not make the coolant fan work.
Steve
Old 09-19-2006, 11:20 PM
Check for blown head gasket
I had an engine one time that had everything in the cooling system working properly and the engine still overheated. I found out later the engine had a blown head gasket. To check for this ON COLD ENGINE take the radiator cap off, fill radiator as full as it will go, start the engine, watch for bubbles in the radiator with a flashlight, when the engine reaches operating temperature. If you get bubbles you either have a blown head gasket, or cracked block or head, and you will have cooling problems.
Old 09-21-2006, 10:46 AM
Hi! This Is Tweety; I Want To Thank Everyone For Their Input To Our Jeep Problem! We Found Out That The Pressure Cap Wasnt Holding The Pressure! Replaced It, And Now It's Doing Great!
Once Again Many Thanks! Tweety
setting points on sb chevy frackster66 Electrical 23 01-07-2014 06:50 PM
crate chevy 302? Vancouver Grand Prix Hotrodders' Lounge 106 12-31-2012 05:05 PM
CA smog questions...engine swaps curtis73 Engine 25 11-28-2012 09:11 PM
53 Packard Clipper Engine Swap? 53packard Engine 16 07-06-2010 05:32 PM
Engine Overheating nabatta Engine 4 06-06-2002 06:12 PM
