engine overheats at hiway speeds - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-01-2012, 08:53 PM
Powork's Avatar
87 Firebird, I wondered what that rubber? piece was below my front spoiler. spoiler should have given me a clue, I thought that the factory just put it on to make it look lower and was told it was to create a low pressure area at speed.
  #17 (permalink)
Old 06-01-2012, 10:57 PM
Localboy808's Avatar
Can you post up a picture of the holes/flaps you installed? I'm having a similar issue. This might be the fix.
Thanks! Scott
  #18 (permalink)
Old 06-03-2012, 02:36 PM
dawg's Avatar
NAVY VETERAN
I got my shroud working perfectly now.
never gets near 200!
both in traffic and going 65-75 on the highway
I used a 2 1/2 inch knockout to make the holes
now to clean everything up.
  #19 (permalink)
Old 06-03-2012, 02:55 PM
T-bucket23's Avatar
Wiki Edits: 26
It is really sad that you spend good money for something and then have to re-engineer it to make it useable.
Chet
  #20 (permalink)
Old 06-03-2012, 03:31 PM
Banned
The quick and easy way for next time is to throw the shroud away. That electric fan without a shroud will be adequate. And as always make sure your timing and fuel is correct. If your tuneup is correct you can use a much smaller fan and be fine as long as you have otherwise good airflow. The fan is only for very low viehicle speeds in which case your engine should not be putting out much heat- if it is tuned properly.
  #21 (permalink)
Old 06-03-2012, 06:24 PM
dawg's Avatar
NAVY VETERAN
these days its always that way!
  #22 (permalink)
Old 06-03-2012, 07:32 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
I have twin Spal fans on my 59
They have the openings with the rubber flaps.
Car still runs a bit warm, but i am not bothered by
anything under 210 - 215 at cruise.
My fans are set to come on at 225 and off at 215.
(454HO and a 5-spd)(BeCool 2 row crossflow---kinda small but nothing
larger will fit in that car.
2 row radiator with 1 inch tubes are plenty for a BB
assuming the radiator is sized correctly.
My 66 Elky with an old SBC 307 also has an aluminum
2 row radiator--again 1 inch tube--but it is a downflow.
Have a set of twin FlexiLites that will cool the car right down
when it gets up to 205.
At cruise, they do not come on and even with the AC enough
air is flowing that the pressure switch on the AC does not always
turn the fans on----unless I come to a stop and air quits moving.
But that engine is virtually stock.
But hey, smogger 307 and a 5-spd gets me better than 25 mpg
  #23 (permalink)
Old 06-03-2012, 07:52 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Dawg, what material is the shroud made out of? Aluminum or stainless? Could you make those flaps out of a chunk of the same material and attach them to the shroud with hinges? It may look cleaner than rubber? Just a thought.
  #24 (permalink)
Old 06-04-2012, 05:39 AM
dawg's Avatar
NAVY VETERAN
aluminum and its being done.
  #25 (permalink)
Old 06-04-2012, 02:54 PM
I hope you'll post up a pic of the updated "flaps" once installed. I've found this thread very, very interesting. My radiator mfr used to provide these type flaps on all their shrouds. They quit doing so shortly before I purchased. I'm looking forward to seeing the cleaner, all metal style flaps.
PatM
  #26 (permalink)
Old 06-04-2012, 05:14 PM
dawg's Avatar
NAVY VETERAN
already got em cut now to get some mini hinges.
Constant miss at hiway speed. BigRoy1978 Engine 9 10-13-2010 10:15 PM
1940 chevy engine 216 overheats after fully rebuilt . ACworks Engine 8 10-08-2010 08:39 PM
My first ever Hiway tire failure. Bryan59EC Hotrodders' Lounge 5 11-02-2008 06:33 PM
running 3,500 rpm on hiway tomthecomic Engine 7 08-28-2007 12:24 PM
Engine hesitation at low speeds ArnoldD Engine 5 08-15-2004 12:32 PM
