engine overheats at hiway speeds - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2012, 04:43 PM
dawg's Avatar
NAVY VETERAN
car runs 170 ish with electric fan running on city and rural streets.
at hiway speeds the car climbs up to 200 and rising, even with the electric fan running.
Ive installed a lower closeout panel
http://undercoverinnovations.com/ind...b0ec9f819e7c5c
its supposed to help cooling but does the opposite on the hiway???
guess ill try with it removed.
car never overheated with the mechanical fan.
since installed a high output electric with 2800 cfm and full shroud
pic here.
185 degree temp switch.
radiator is a 2 core sized for BB chevy.
I did notice the inlet of the rad was squished a bit to allow welding to the side tank.
(might be a restriction)
upper hose is hard when at proper temp.
the shroud and fan covers the whole core area
pic:
I ran a direct mechanical 6 blade fan with factory shroud (always spinning) temps stayed 165 to 175 with the radiator im using now and upper closeout panel.
All i added was the above electric fan/ shroud with 185 degree temp switch and lower closeout panel.
I even uncorked the usually blocked rear water passages and ran hoses bypassing the thermostat to aid in cooling.
Old 05-27-2012, 05:20 PM
I had the exact same problem with same setup on my '32. Took the shroud off, solved problem. Shroud won't let enough air pass thru at speed.
Old 05-27-2012, 06:28 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Go here and read about cooling: http://www.crankshaftcoalition.com/w...cooling_system
Two core rad....Big block......no!
Old 05-27-2012, 06:39 PM
dawg's Avatar
NAVY VETERAN
2 core aluminum rad made for big block but I have a smallblock lol.
I read somewhere to install rubber flaps that open at highway speeds!
Old 05-27-2012, 06:45 PM
Richiehd's Avatar
JS-70
Also make sure that lower hose is not callapsing at speed. That needs to have a coil spring in it to keep it open.
Usually overheating on highway is not enough cooling system, overheating in driveway, not enough air flow. Might need 3 row radiator
Old 05-27-2012, 07:06 PM
I cut 4 holes in my rad shroud & installed rubber flaps, no help. But, what works 4 1 person won't work for anutter. Is that a 16in puller fan?
Old 05-28-2012, 05:25 AM
dawg's Avatar
NAVY VETERAN
yes spal HP puller 2025 CFM.
the cooling sytem is good rad is more than big enough.
Keep in mind the system wasnt an issue with factory shroud and mechanical fan!
Old 05-28-2012, 06:30 AM
If the timing is a little slow it will make an engine run hotter on the highway. Won't cost anything to double check it.
Old 05-28-2012, 06:47 AM
dawg's Avatar
NAVY VETERAN
chatted with the local radiator shop owner while the wife and i had breakfast in a local diner.
He stated that my problem is common with the custom shrouds.
they cool good under 30 mph or so but fail to cool at anything higher.
he said additional holes need to be made in the shroud and thin rubber flaps will need to be placed over holes.
by thin he ment .010 to no more than 1/32"thick rubber so incoming air will open them causing flow through the radiator and suck closed at lower speed.
Old 05-28-2012, 06:50 AM
dawg's Avatar
NAVY VETERAN
Timing was checked and rechecked .
I even had the car on the sun diagnostic machine (remember those?)
all plugs firing good and timing is perfect.
I even had the distributor (new unilite) put on a distributor machine to check it.
Old 05-28-2012, 07:36 AM
FASTFORD's Avatar
since it only overheats at highway speeds, it could be that more air is flowing around/under/over the radiator than thru it.
Old 05-28-2012, 08:34 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
H Dawg, thank you for your service haven't seen you around much or for a while. You probably know what i am going to say but here it is anyway, loose the electric fan go back to a good stock style mechanical or a real good aftermarket fan With a shroud. JMO and if you want to continue to use the pulley set-up you have on it now which i really like. just machine the water-pump pulley so the mechanical fan is recessed in the pulley and then all should be good. I have been there done that Dawg either way good to see you again. If you need pics of exactly what i done on my pulleys let me know .
Cole
Old 05-28-2012, 10:13 AM
T-bucket23's Avatar
Wiki Edits: 26
That fan / shroud setup is not allowing ample air flow at speed. Looking at it it is probably covering about 30% of the radiator. this will cause air to go around instead of through. Sealing the top of the radiator to the support may help a little. On the highway that shroud is doing more harm than good. On the highway you don't need a fan as natural airflow should be more than enough.
You said it worked fine with the stock fan and shroud, this tells the whole story.
If you have a manual switch on the fan try turning it off on the highway and see if it helps, the fan can also impede air flow.
Chet
Old 05-29-2012, 03:29 PM
dawg's Avatar
NAVY VETERAN
the mfg suggest I kick out the bottom for a 1/2 to 1.0" gap to allow air to flow.
if it works I should place a few 2" holes with 1/32 rubber flaps to correct issue.
if angling doesnt work they offered to refund my money for the shroud/fan assy.
Old 06-01-2012, 06:15 PM
dawg's Avatar
NAVY VETERAN
BS! you dont know what your talking about!
the panel actually directs more air into the radiator.
mFg write up:
This panel was originally plastic and installed on the big block a/c cars. GM knew that the air was being re-introduced to the front of the radiator when idling. At speed the pressure from air coming under the core support was working against the flow of air through the radiator, so this panel was designed. The GM panel only goes as far as the core support.
We wanted to force ALL of the air from the grille through the radiator, so ours goes all the way up to the backside of the spoiler (or the valance). It has a divider at the core support to finish off the seal. It will protect youir lower pulleys from picking up debris and flinging it all over your motor. You wont stir up as much dust when you are cruising because all of the air off the radiator is directed to the rear of your engine.
without it it is runnin hotter.
cut the holes and installed the rubber flaps.
car stays at 180 degrees now either in city traffic of on the Hiway.
Ya learn something new everyday!
even a know it all learns aswell sometimes!
Constant miss at hiway speed. BigRoy1978 Engine 9 10-13-2010 09:15 PM
1940 chevy engine 216 overheats after fully rebuilt . ACworks Engine 8 10-08-2010 07:39 PM
My first ever Hiway tire failure. Bryan59EC Hotrodders' Lounge 5 11-02-2008 05:33 PM
running 3,500 rpm on hiway tomthecomic Engine 7 08-28-2007 11:24 AM
Engine hesitation at low speeds ArnoldD Engine 5 08-15-2004 11:32 AM
