Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine Painting Question
  #69 (permalink)
Old 01-21-2013, 01:30 PM
dbrow6272 dbrow6272 is offline
oldtimerodder
Last journal entry: 52 Chev PU
Engine paint
You can spray urethane over rattlecan paint if you leave the catalyst out. Try it on a small part first to ensure it will not lift. Just use clear and the hardener 1to 1. I have used this "trick" over old style enamel pin stripping and it works fine.
