Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine Painting Question
  #84 (permalink)
Old 03-02-2013, 04:19 PM
zmaxmotorsports's Avatar
zmaxmotorsports zmaxmotorsports is offline
Originally Posted by bsa_bob View Post
I would get that paint out of the enginethats not a good thing!It will evntually break down,and may travel to the oil pump; via the lifter vally drain holes etc. I just would not do this. You've never seen a engine painted inside have you.? This is definetely for this reason. looks good now ... no-run tomorrow
That's what that glytol is made for,sealing the inside of electric motors.
People have been using it inside lifter galleys to aid oil return since long before I was around without problems,they also use it to seal the inside of those porous *** Harley Davidson engine/trans castings
