I'm going with Duplicolor "Cast Aluminum" on my aluminum LS and 6L60. I know. It seems redundant!
327NUT What size is you cadillac engine ,I am looking at a 1970 500 to go in 1950 Chevy pu i will leave close to stock exept aluminum heads and intake ,from what i have read it only weighs 70lbs more than small block chevy so head $ intake shoukd balance out ,any tricks you know I should look out for Thanks
Mine is a '75 500 bored .030 making it a 507, you don't need aluminum heads, besides they are $3500. The '70 500 engine had 76 cc combustion chambers and around 10.1 compression. A good rebuild with the Edelbrock 2115 intake, a Holley or Quick Fuel Tech carb and a #10 cam from "Maximum Torque Specialties" will really set that engine free. Take a look at their website at Index and also look at Cadillac Forum, join the forum and see all kinds of big Cadillac engine builds.
engine painting
Remember , with rattlecan paint oil and gas will strip it faster than you can yell a curse word ! Ive found that urethane clear with hardener will cover any rattlecan paint ,ANY , and youll end up with a super shiney , long lasting , solvent protected finish that will make you want to open the hood . I paint a lot , many parts , so I keep it around but a Qt. of clear and Pt. of hardener will run you maybe 50 bucks and youll be surprised how often youll use it ! Wheels , hood bottom sides , engine compartments and the list goes on and on . If you dont have a compressor , you probably dont do paint at all anyway . Wear a respirator !
i have used dupla color it lasts for about two years and then dulls . would like to try the eastwood stuf its abit pricey but cleaning a block is a lot of work . back in the good old days oven cleaner would take off all the old paint grease grime. but they took all the good stuf out of it.
How long will the eastwood paint last?
Engine paint
You can spray urethane over rattlecan paint if you leave the catalyst out. Try it on a small part first to ensure it will not lift. Just use clear and the hardener 1to 1. I have used this "trick" over old style enamel pin stripping and it works fine.
Paint
OPPS I must apologize I meant to say leave the thinner out and only use the hardener. It works very well.
Engine paint
I really must apologize. It has been a number of years since I have painted urethane over enamel and I plain got mixed up. The reducer used in the urethane paint is much stronger than enamel or old lacquer for that matter, it will eat through the underpaint and lift---bad! So use 1 part clear and 1 part hardener and you will be ok. Remember do a small test panel first to ensure the paint will not lift. No if memory serves me, I'm in the middle side of 60, you can really pour on or I should say heavy coat the clear mixed this way and it should not run. I have intentionally orange peeled the paint and it flows together nice. Takes a long time to cure unless you use heated lamps, then paint it like normal don't lay it on really thick. Medium coats will work fine. And the finish is smooth like glass.
| Painting Engine question | roykuz | Engine | 7 | 07-22-2008 06:03 PM |
| Painting an engine! | Fragzem | Engine | 2 | 05-10-2004 05:11 PM |
| painting my engine | Echofive | Engine | 2 | 12-06-2003 10:38 PM |
| Engine painting | nomis30 | Body - Exterior | 1 | 09-20-2003 05:19 PM |
| Painting an Engine | Jackyl | Engine | 8 | 04-09-2003 04:14 PM |
