Engine Painting Question - Page 7 - Hot Rod Forum : Hotrodders Bulletin Board
  #91 (permalink)
Old 05-24-2013, 09:02 PM
bigdog7373's Avatar
Of course it's fast
stap.
thread is old
  #92 (permalink)
Old 03-12-2014, 04:33 PM
bsa_bob2's Avatar
Originally Posted by HrdNox View Post
Seal it and paint no need for hi temp.
heres your best answer i would just ad dp-90 let it set 30 minutes then lay your epoxy color. it will be there longer than rattle can.although as was said her earlier/ engine paint doesn't need to be heat proof paint. But non of it stays nice. believe this i know after half my 20 some builds bob s
  #93 (permalink)
Old 03-12-2014, 05:34 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Originally Posted by Richiehd View Post
That inside is painted with Glyptal, thats painted for oil control. Used extensively in racing applications. There are a couple of threads here on it. Don't worry, it's not coming off.!!
I Know this is an OLD post but as you said to the above post I also paint the inside valley with Glyptal Gray designed for electric motor after gringing valley smooth and chamfering drain backs and I useepoxy to hold in drain back screens to catch any debris,,needlebearing from roller rockers or broken studs or pushrods ,metal chips in oil pump not good ,,as do all racers in this area,
just a side not after cleaning the block as clean as possible I use a heat gun and a hand held propane torch to remove ALL signs of grease ,oil or FINGERPRINTS before painting POR 15 is a great choice there is not a chemical that I have found that will remove it, one of my recent builds
ID:	127681   Click image for larger version
Name:	GUAGES AND STERRING COLUMN 008.jpg
  #94 (permalink)
Old 03-12-2014, 07:36 PM
327NUT's Avatar
Old thread.........oh well, here's my Cadillac with the Glypta.l
ID:	127705   Click image for larger version
  #95 (permalink)
Old 03-12-2014, 07:43 PM
Built Not Bought
Thay looks great looks like the top of cyl have ben taper honed at top to make rings easier to install
What is tha big ole 500 Caddy going in,
shaft mounted roller rockers a nice touch making a stable valve train,
  #96 (permalink)
Old 03-12-2014, 07:46 PM
Built Not Bought
[quote=496CHEVY3100;2190849]Th
  #97 (permalink)
Old 03-14-2014, 09:28 PM
327NUT's Avatar
The Cad was already .030 with only 30k on the orig rebuild, no ridge or taper so we just kissed the cyls. for a set of cast rings. It's going into this ....Eventually. All new parts except pistons, built it for today's crap gas so it's 8.7:1 comp. but it still dyno'd 466 hp and 535 torque at 4300 rpm. It's going to have this for a home.
  #98 (permalink)
Old 03-14-2014, 09:37 PM
327NUT's Avatar
I screwed up...........here's the new home.
ID:	128122   Click image for larger version
ID:	128130   Click image for larger version
Name:	000_0465 (1024x682).jpg
  #99 (permalink)
Old 03-14-2014, 11:54 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Nice Your garage too !!!! Mine is flooded from the 4 foot snow & ice melting around it LOL !
I'll be up all night sweeping and pumping the water out
Jester
  #100 (permalink)
Old 07-23-2015, 05:57 PM
67Elcamino's Avatar
That is one nice looking engine. I know this is an old post but what type of paint did you use and how is it holding up?
I plan on painting an engine soon with Epoxy primer and House of Kolors Basecoat Kandy oriental blue.
Wondering how it'll hold up
Painting Engine question roykuz Engine 7 07-22-2008 06:03 PM
Painting an engine! Fragzem Engine 2 05-10-2004 05:11 PM
painting my engine Echofive Engine 2 12-06-2003 10:38 PM
Engine painting nomis30 Body - Exterior 1 09-20-2003 05:19 PM
Painting an Engine Jackyl Engine 8 04-09-2003 04:14 PM
