-   -   Engine Painting Question (http://www.hotrodders.com/forum/engine-painting-question-217541.html)
big_wave_dav 03-30-2012 08:44 AM
I currently have my engine out & am getting ready to paint it. It's been cleaned and its down to bare metal in some places. Do I need to prime it with high temp. primer or just go ahead & shoot it with regular hi temp. engine paint?
Thanks in advance for your replies.
speedbump 03-30-2012 10:41 AM
Duplicolor makes a rattle can system that has primer, color and clear. All high temp engine paint. I like it close to the Eastwood stuff that you have to spray with a gun. Just depends on how pretty you want it.
327NUT 03-30-2012 12:00 PM
1 Attachment(s)
Just painted my Cadillac block with DupliColor engine primer and enamel. The inside red color is Glyptal, not really necessary but I had a can of it so why not.
Richiehd 03-31-2012 02:41 PM
I did mine today, as a matter of fact. I used the Eastwood stuff, with hardener, sprayed with touch up gun. Did aluminium intake as well as the rest of the motor, No primer.
lmsport 03-31-2012 04:24 PM
I would suggest you use aerosol stripper to get all of the old paint off.
I have had the best luck with catalyzed auto body enamel in terms of durability. I have not seen the rattle can stuff stay on more than a year or 3.
327NUT 03-31-2012 04:34 PM
The "rattle can stuff" stays on just fine ....if you use a good quality paint made for the application and do the proper prep work before painting. Not eveyone has a compressor and spray gun to paint a block and related parts.
bondo 04-01-2012 05:42 AM
Ayuh,... I paint my motors with rattlecan Rustoleum....
Never had any paint loss, except for the hot spot on the intake manifold, at the cross over...
speedbump 04-01-2012 01:11 PM
I also use the Eastwood stuff with hardener at times. Makes a really nice glossy finish. Even better than the Dupliclolr clear, but more of a hassle.
HrdNox 04-01-2012 01:21 PM
2 Attachment(s)
Seal it and paint no need for hi temp.
speedbump 04-01-2012 01:37 PM
Nice job!!!
Richiehd 04-01-2012 07:27 PM
2 Attachment(s)
Eastwood with hardener. I know its Ford dark blue, going in a blue and white boat
Prof. T. Soggmeyer 04-01-2012 08:32 PM
1 Attachment(s)
Eastwood with hardener, same color as the body.
67-4-fun 04-01-2012 10:56 PM
is there a red close to a candy red to paint an engine of that color?
68NovaSS 04-02-2012 07:31 AM
Take a trip to the parts or paint store or search online for color chips for crying out loud! :drunk:
67-4-fun 04-02-2012 06:32 PM
Just thought I'd ask no big deal
