Engine Painting Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2012, 08:44 AM
I currently have my engine out & am getting ready to paint it. It's been cleaned and its down to bare metal in some places. Do I need to prime it with high temp. primer or just go ahead & shoot it with regular hi temp. engine paint?
Thanks in advance for your replies.
Old 03-30-2012, 10:41 AM
Duplicolor makes a rattle can system that has primer, color and clear. All high temp engine paint. I like it close to the Eastwood stuff that you have to spray with a gun. Just depends on how pretty you want it.
Old 03-30-2012, 12:00 PM
327NUT's Avatar
Just painted my Cadillac block with DupliColor engine primer and enamel. The inside red color is Glyptal, not really necessary but I had a can of it so why not.
Old 03-31-2012, 02:41 PM
Richiehd's Avatar
JS-70
I did mine today, as a matter of fact. I used the Eastwood stuff, with hardener, sprayed with touch up gun. Did aluminium intake as well as the rest of the motor, No primer.
Old 03-31-2012, 04:24 PM
I would suggest you use aerosol stripper to get all of the old paint off.
I have had the best luck with catalyzed auto body enamel in terms of durability. I have not seen the rattle can stuff stay on more than a year or 3.
Old 03-31-2012, 04:34 PM
327NUT's Avatar
The "rattle can stuff" stays on just fine ....if you use a good quality paint made for the application and do the proper prep work before painting. Not eveyone has a compressor and spray gun to paint a block and related parts.
Old 04-01-2012, 05:42 AM
bondo's Avatar
Ayuh,... I paint my motors with rattlecan Rustoleum....
Never had any paint loss, except for the hot spot on the intake manifold, at the cross over...
Old 04-01-2012, 01:11 PM
I also use the Eastwood stuff with hardener at times. Makes a really nice glossy finish. Even better than the Dupliclolr clear, but more of a hassle.
Old 04-01-2012, 01:21 PM
Seal it and paint no need for hi temp.
Old 04-01-2012, 01:37 PM
Nice job!!!
Old 04-01-2012, 07:27 PM
Richiehd's Avatar
JS-70
Eastwood with hardener. I know its Ford dark blue, going in a blue and white boat
ID:	64532   Click image for larger version
The Following User Says Thank You to Richiehd For This Useful Post:
zmaxmotorsports (03-02-2013)
Old 04-01-2012, 08:32 PM
Prof. T. Soggmeyer's Avatar
Plan B
Eastwood with hardener, same color as the body.
Old 04-01-2012, 10:56 PM
is there a red close to a candy red to paint an engine of that color?
Old 04-02-2012, 07:31 AM
68NovaSS's Avatar
Wiki Edits: 9
Take a trip to the parts or paint store or search online for color chips for crying out loud!
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
Old 04-02-2012, 06:32 PM
Just thought I'd ask no big deal
Painting Engine question roykuz Engine 7 07-22-2008 06:03 PM
Painting an engine! Fragzem Engine 2 05-10-2004 05:11 PM
painting my engine Echofive Engine 2 12-06-2003 10:38 PM
Engine painting nomis30 Body - Exterior 1 09-20-2003 05:19 PM
Painting an Engine Jackyl Engine 8 04-09-2003 04:14 PM
