Engine in pic - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2008, 11:50 PM
need strog32 chevy front doors
Last journal entry: Tbd
Help! first time positioing engine
Hey all
i put my engine in and left the front of grill 3 inch from the radiator for room for an electric fan down the road, and ileft 2or so inch fromt radiator to the fan.
doesmthis lookweird to you??
ID:	31999   Click image for larger version
Old 08-23-2008, 09:33 AM
any ones comments wood be greaty appreciated
Old 08-23-2008, 09:55 AM
Hi,
looks fine to me. keep up the good work.
sam-missle
Old 08-23-2008, 10:58 AM
you sure? if so thanks . I still got to level the manifold. still got to put the tranny mounts in.
Old 08-23-2008, 11:15 AM
one more thing to ask
i want to use the s10 tailshaft. does it have the locate the tranny rubeer mount in the same place as the camaro tailshaft does?
Old 08-23-2008, 12:45 PM
Originally Posted by 31chevy
Hey all
I like the chain; a little Dungeons and Dragons adds some class to the typical hot rod project.
Actually 3 inches and 2 inches is a bit tight. Puller fans are more effective than pusher, as when installed with a radiator core perimeter shroud they will pull air thru more of the core area than can be achieved with a pusher fan. So if you can fiddle the dimensions, I'd try to add more between the radiator and the motor as the more streamlined the shape of the shroud the more effective it is.
Bogie
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
1985 C-6 truck tranny, no engine braking effect fast68 Transmission - Rearend 40 02-04-2008 05:55 PM
pontiac engine noise, possibly rod knock? Blob Engine 4 08-06-2006 02:01 PM
pic of engine 71montebbc Hotrodders' Lounge 1 11-05-2003 03:31 PM
