Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine pinging
Thread: engine pinging
Old 07-12-2007, 05:38 AM
baddbob baddbob is offline
Use some AC spark plugs in the 43 or 42 heat range, I bet that'll help the problem. You also might be able to switch to steel shim head gaskets if the piston to deck height is .020ish
