Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine pinging
Thread: engine pinging
  #19 (permalink)
Old 07-15-2007, 12:38 AM
baddbob baddbob is offline
What heads are on the motor? I believe the R44TS? is a longer reach plug (for the later design heads) than an R44T and if you're using the wrong length plug the exposed threads could be glowing hot and causing the spark knock-possible. Check it out.
