engine pinging - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2006, 05:39 AM
jpelli's Avatar
engine pinging
I have a 350 chevy with vacuum advanced hei ignition. The engine will ping like mad one time, than the next not ping at all. Have tried reducing the timing this didn't work, at a loss any suggestion?
Old 07-25-2006, 06:27 AM
Not A T 25's Avatar
Takes Guts To Cut One Up
I would try different gas if the gas you use is different from one time to the next the quality and octane rating could be different is the 350 stock? does it ping under load or at cruse and idol, You could also have a lean condition on your carb check your plugs to see how they read.
Old 07-26-2006, 12:03 PM
jpelli's Avatar
I disconnected the vacuum advance and the ping is gone. don't know if I should replace the can or try to adjust it, although I can't see how it could change settings. Joe
Old 07-26-2006, 12:41 PM
Not A T 25's Avatar
you can check the can utilizing your timing light to see how much advance it puts in when you hook it up, but the best way is to go by an Auto Zone or someplace like that and rent a vacuum test pump then you can check how much advance you get and at what in of vacuum. Check you vacuum lines for leaks also do you have it hooked to manifold or ported vacuum source?
Old 07-26-2006, 01:18 PM
lamothe1's Avatar
Check to see if the small springs on the advance are in place. Maybe one came off and it's letting it advance to fast or maybe their the wrong ones (you can buy different size ones at Kragons and Auto Zone).
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
ENGINE BALANCING NAIRB Engine 14 09-06-2011 08:22 PM
1973 Chevelle Malibu Engine Rebuild (pics 56k no) Malibu73 Hotrodders' Lounge 39 11-04-2008 12:37 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
question for any engine builders out there mopar72 Engine 7 11-06-2005 03:06 PM
