engine problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2009, 01:37 PM
engine problems
ok so i have a 79 chevy with a 350 v8 in it and all the emissions crap has been taken out so i know thats not the problem. i HAD a knocking noise in the engine a while back and i thought i had the same problem as my 81... driving it with no oil but after thinking about it i didn't have the same noise as my 81 plus it had oil at all times and i made sure of that. i was driving my 79 and as i went around a corner i put my clutch in and while the engine was winding back down it kinda made a slightly louder banging noise and died, she didn't want to start back up after that. the starter couldnt even turn the fly wheel once. people have told me that a rocker arm might have fallen off it's pushrod as a result of reving it too much or running it at high RPM's for a long period of time. now my question is what is the best way to check what the problem is myself? and if a rocker arm did just fall off would i have to replace parts like the rocker arm or pushrod or both? please help me i want my truck back
thanks,
Jon Eastman
Old 02-26-2009, 02:17 PM
pontiacjosh's Avatar
84 stroked ss
Last journal entry: exhaust
it sounds to me like it is more then a rocker arm and how loud is was the noise and it could even ba a wrist pin or a bearing spun need more info
Old 02-26-2009, 02:23 PM
84 stroked ss
it may have also jumped time but if it is a pushtube if it is still straight and clean through the center you can reuse it and the rocker arm just have to get the rocker arm torqed properly
Old 02-26-2009, 03:56 PM
bondo's Avatar
Ayuh,... Pretty Simple,.. really...
Pull the Valve Covers,...
If you don't see the Problem,...
Pull the Intake,...
Pull the Heads,...
Pull the Motor...
Flip it over,+ pull the Oil Pan,...
That's where the Answer will be.....
Old 02-27-2009, 02:44 PM
Big Don's Avatar
engine problem
If it won't turn over at all---- Then it is more then just a push rod, don't you think?
Old 02-28-2009, 11:44 AM
84 stroked ss
iwould most likely say a rod or main bearing
Old 03-02-2009, 12:19 PM
more info
well when it was running at idle it was fine and there was no noise, purred like a tiger, rev it to 2k rpm and it got pretty bad.... after 2k as long as i was accelerating you couldn't hear it but any where between about 2k and 5k rpm if i was cruising (or holding the rpm at any certain point) then it got terrible made my guts turn listening to that thing. also rapping down there wasn't a noise but it kinda sounded "different" or not as good as it used to be. about a day ago i tried putting the key in and tried starting it just for ****s... it turned 2 times SLOWLY then stopped, but after that i tried and it turned twice again but still it gave up so it will turn over a small amount of times, and slowly but it won't start.
Old 03-02-2009, 12:22 PM
DoubleVision's Avatar
You can pretty much write it off. It`s rebuild time. Seen one do this before many years ago and it had spun several bearings.
CA smog questions...engine swaps curtis73 Engine 25 11-28-2012 09:11 PM
engine hesitating and other problems 68ford Engine 6 08-18-2006 09:12 PM
84 mustang engine idle problems naarman Engine 1 07-22-2006 09:42 AM
84 mustang engine idle problems naarman Transmission - Rearend 1 07-21-2006 09:43 PM
Cam Help black66 Engine 3 05-12-2003 07:15 PM
