Engine is Purfect. Except for SMOKE. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2002, 08:57 AM
Post Engine is Purfect. Except for SMOKE.
The engine finally is cooled down and runs well at just over 1000RPM. I have the time bang on and am totally pleased with all the help and hard worku and I have put into this engine. But it still is smoking from the rear exhaust manifolds on both side. I am not sure if it is still oil from when the vavle covers were leaking or if I have a problem Inside the motor. Any help thanks and is appreciated. Thanks again guys and girls.
Zee
Old 07-22-2002, 09:36 AM
Madd Syntst's Avatar
Returning American Maddman
Post
Be methodical. Go after the easy stuff first. Valve cover gaskets OK? PCV leaking? Intake manifold leaking from the back. After running a short time, the oil on the manifold should disapate. If it continues, you have a leak. If it is smoking from the exhaust itself, check oil returns, then go to valve seals. It is how I woul start.
Too serious? Ah, buy a box of Black and Mild Cigars and ignore it
