Engine question!! - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-26-2010, 05:20 PM
Dirty Biker's Avatar
Bold As Love
I think a motor with a short stroke, a conservative cam, and long rods is the best. Some disagree and say big stroke and low rpm and overdrive. According to dodge-wiki there was a rambler that got 51.2 mpg in a pretty good sized car wayyy back in 1960.
http://www.dodge-wiki.com/wiki/Rambler_American#Economy
The motor was an inline six and had a short stroke and long rods. I bet it had a good amount of compression. But yeah honda does a thing with a pre combustion chamber that they call a "lean burn" head or something. There is also a guy that claims great mileage from hot air, preheating the intake charge.
Smokey Yunick! http://www.legendarycollectorcars.co...clusive-video/
still only 51 mpg, and a smaller car too. The AMC is not too bad for 1960 tho!
  #17 (permalink)
Old 08-26-2010, 07:28 PM
Originally Posted by cobalt327
But man, the EMISSIONS!!
Yeah but the emissions are biodegradable!
  #18 (permalink)
Old 08-27-2010, 08:13 AM
BigRoy1978's Avatar
yeah, but that Rambler was built to get MPG. They did a whole mess of work to that car to get those numbers, including disabling 1st gear on take offs, so it would pull through second and not rev up as high.
I say! 5.8 liter 12 valve Cummins, like what dodge put in the 90's trucks. We tuned one in tech school to get something like 45-48 mpg. Then we could just adjust the fuel curve, injection timing and pressure and get nearly 1000 horsepower, with one turbo. We had it near 45-50 pounds of boost with the stock turbo, but i wasnt there to see the numbers when they put twins on it.
Or! if we are talking mpg, medium sized engine...say a 327, with a really nice combustion chamber/piston design, gobs of compression, and then run it into a 700r4, with an overdrive unit on the back of it, with something like a 3.08/2.80 something gear. then take that and put in a low/light/streamline car, lets say a 77-81 F-body! You could cruise at 150 mph, and get something like 30 mpg! No, it would accelerate as nasty as one would want, but damn, it would top at at something like...hold on ill do the math. 461 mph! minus wind/bug/space time contineum resistance, and i bet it would realistically do 220-230!
I had another senario...but ill stop there.
  #19 (permalink)
Old 09-04-2010, 07:21 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
The Ramblers had to be certified stock for the economy runs, that's one reason NASCAR supervised everything. They weren't powered by short stroke engines, most of the high mileage cars used the old 195.6 L-head ( Americans only, the bigger Ramblers used the 195.6 OHV) like Martinsr built for his 60 American. First gear wasn't "disabled". Those cars typically used a three speed OD trans and averaged around 40 mph for the long runs. The old OD units will freewheel when the driveshaft spins faster than the engine to prevent over revving -- the drivers took max advantage of that. They likely did start in second gear. The old long stroke/small bore sixes were like tractor motors, they could be lugged without choking down or "jerking" like modern cars will (one old American I had was the only stick shift my ex wife could drive on anything but a flat surface!).
The main thing is how you drive. Keep speed around 35-45 and don't get in a hurry to do anything and piss everyone else on the road off. Then you too can get 25-30 mpg out of an old Rambler! Drive a Honda like that (well, you can't lug it, but with a stick could push in the clutch and coast down hills) and you can probably get 40+ mpg. A typical driver would average about 20 mpg in that same Rambler driving normally. Of course it won't take off but so quick, and it's most comfortable cruising in the 45-60 mph range (over 60 is pushing it a bit, but you won't blow the tank motor up). So you can't help but average around 20 mpg in them. Same with old VW Bugs. Lots of people seem to think they got great mileage, and they did FOR THE TIME. Bugs average about the same as the Ramblers -- 20 mpg for most, with careful driving up to 25 mpg. But most American cars in the late 50s and early 60s got 15-16 mpg on average, or less, so another 5 mpg or so is great! That's right, no 30 mpg bugs... but it sure seemed like it after driving the old big Chrysler around for a while!
  #20 (permalink)
Old 09-04-2010, 05:57 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Let me see??
Hotrodding --vs-- Efficiency.
You have wandered into a zone of no return. Get out fast or forever regret your actions.
vicrod
  #21 (permalink)
Old 09-26-2010, 12:54 PM
Bold As Love
According to this engine data table the stroke was only 3 inches on a 199 amc 6 cylinder, with a 5.875 rod. Three inch is pretty short.
http://victorylibrary.com/mopar/m-table-c.htm#AMC
  #22 (permalink)
Old 09-27-2010, 02:13 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The 195.6 cid L head engine had a 3.13" bore X 4.25" stroke- and is the "mileage" engine being discussed above.
  #23 (permalink)
Old 09-27-2010, 02:45 PM
ericnova72's Avatar
More for Less Racer
At the Victory Library link, you have to look it up under "Rambler" not "AMC".
  #24 (permalink)
Old 09-30-2010, 06:43 PM
topwrench's Avatar
Last journal entry: fish carb
"stock cars" that ran certified milage runs were massaged a lot
Engines taken apart and loosened up
100 pounds of air in tires(gauge read 26)
carbs leaned out to max
Even the bearing grease and brakes were played with
Best milage depended on the driver....
Drive like there is an egg between foot and accelerator pedal!!!
  #25 (permalink)
Old 09-30-2010, 07:11 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The Mobilgas Economy Runs were done for many years, they were always a bragging point for the winning marque, rags like Motor Trend, Car and Driver and Road and Track would have articles on the event, and even HR would mention them.
  #26 (permalink)
Old 09-30-2010, 08:09 PM
You want economy? Check out his link! http://strangevehicles.greyfalcon.us...OLKSWAGENS.htm
  #27 (permalink)
Old 10-01-2010, 08:36 PM
KA67_72's Avatar
I got what you need right here. Check this bad boy out:
http://www.gizmag.com/go/3263/
It makes peak hp at 102 rpm with over 50% thermal efficiency. Stick that in your Prius and smoke it. Hippies!!!! If you trade in your paid for 12mpg pickup you'll just need to drive it 18 bagillion miles a month to break even.
Kevin
  #28 (permalink)
Old 10-01-2010, 08:55 PM
Landshark928's Avatar
FrankenPorsche
How about this in your four banger. Help the environment and still feel like a bad ***.
http://www.youtube.com/watch?v=b9XAC-BvUyo
