engine rebuild - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2003, 09:10 AM
65galaxie500's Avatar
Question engine rebuild
Ok my 390 block is at the machine shop getting checked and bored. should i also have my crank and rods reconditioned? what other things should i have done at a machine shop while its tore down? should i go with a multi angle valve job or is the cost really worth it? im not building a race car but i dont want to be kicking myself because i didnt have something done that i wish i had. thanks
Old 04-02-2003, 09:29 AM
4 Jaw Chuck's Avatar
Post
If the crank is clean and not scored...have it micropolished and leave it standard size.
Have the rods resized with new quality bolts.
Most valve jobs are already 3 angle, if you want something special get 5 angle...the difference in performance will be negligable unless your running at the ragged edge. If your handy with a grinder pocket port the valve bowls, don't polish.
If the block is straight then leave it but have the cylinders bored and honed.
That's pretty much it?
Outlawed tunes from outlawed pipes
