Engine Rebuild. HP?? Torque?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2005, 12:58 PM
I am rebuilding a 350 from a 1970's era truck. I am going to put this into a landcruiser for trails, trips, maybe a daily driver, towing, etc.
I want to make sure that I have enough HP and torque to tow my crap around if I need too. I do not need a crazy amount of HP and torque. I need more then anything reliablilty.
Any suggestions on how far I should bore? I was thinking .020. It is at stock now. Cam? Pistons? Valves? Timing?
Thanks
Old 12-29-2005, 01:51 PM
Ozz1967's Avatar
Air Force Guy
I wouldn't bore it out at all unless the cylinder walls require it. You can easily get 350-400hp and 350-400 foot pounds of torque out of a 350 depending on what you do. Also, 350's are about as reliable as they come.
However, if you are going to bore it out, go .30 over and put in a new crank with a 3.75 inch stroke to make the thing a 383 stroker motor. Good power and great torque. In the end, it depends on how much you are willing to spend on your project.
Old 12-29-2005, 01:56 PM
Drive it Like u Stole it!
in my opinion, for what you intend to use it for, you should be aiming for more torque than horsepower. finding a good "rv cam" would be your best bet. as far as the machine work on your block, just machine it out as far as it needs to go to be straight. if it ends up being 0.010, 0.020, 0.030, or 0.040 that is what it has to be to be correct. stock crank, stock rods, new bearings, new gaskets - everything that needs to be replaced to work. with your heads, get them cleaned up as well, and maybe a mild port job or valve job or both! you might even want to find different heads that would bolt on (vortec) and could be found cheaply. intake manifold too... 4bbl aluminum with a nice 500-600cfm carb on top. there's million different "stock-type" options you can go through to keep costs down. as far as reliability, every engine would last long if it was assembled properly and never abused while driving. dont expect it to last long if you spun it 7k rpm every day!
Old 12-29-2005, 02:40 PM
Thanks for the advice.
I am on a budget so I think that I will try to stick to stock as closely as possible. The temptation is there though to really give this some power, but I don't want to break any axles or drivelines on the trail.
I would imagine that I probably would not need to get forged pistons, hyper-cast would work ok...thoughts??
You are right on about the torque, that is mainly what I am aiming for here. With bigger tires, 35" probably, I will need at least 300 ft lbs, if not more with a trailer behind me.
Also I will be running an NV4500 behind the 350.
Thanks again, it is greatly aprreciated.
Old 12-29-2005, 04:49 PM
larryblack's Avatar
Certified Lead Foot
I suggest you try the crane cam for RV applications and put it 4* advanced. You will get tons of low end torque, good vacuum and it idles right smooth. Use a 600 cfm carb too.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 11:22 AM
235 engine rebuild gavinpierce Engine 8 09-22-2005 03:35 PM
how hp torque do i have? (460) a2b Engine 1 01-11-2004 09:29 PM
Engine rebuild ...... Help stingraymax Engine 2 11-11-2003 07:17 PM
