Is engine rebuilding a dying art? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2006, 06:48 PM
strummin67's Avatar
Violating consensual reality
Last journal entry: It tows!
I spent some time today trying to get numbers for a small block Chevy rebuild but I can't find anyone to do it. I live in the southern San Francisco bay area. Any of you local guys know of a good shop?
Strummin
Old 12-12-2006, 07:31 PM
mynuffinfutsitch's Avatar
y not try it urself?
Old 12-12-2006, 07:36 PM
strummin67's Avatar
I'd like to but I don't have a garage or the space.
Old 12-12-2006, 07:40 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
PM Powerrodsmike and ask him........he is a member here...he lives in Gilroy.
Old 12-12-2006, 07:42 PM
strummin67's Avatar
Yeah. I've seen him around. I'll ask. Thanks!
Strummin
Old 12-12-2006, 07:45 PM
poncho62's Avatar
Wiki Edits: 5
These days, with mass production, it is probably cheaper to buy a crate engine............and probably a better warranty.
Old 12-12-2006, 07:46 PM
Lost in the 60's
Wiki Edits: 4
He has his own business....he is one of the best.
Old 12-12-2006, 07:49 PM
Lost in the 60's
Wiki Edits: 4
Yep...unless you restoring one and want your own engine because it is numbers matching. I did my own in the coupe ( all but the machine work of course)..........I was not worried about warranty....I re-built them for 39 years making my living.
Old 12-12-2006, 08:39 PM
Hi Strummin67
I'm in Milpitas, and have discovered Gromm Racing heads. Bob Gromm is the owner, and built the business from the ground up. He's done lots of hot boat motors and even a few rocord holders, I think.
If you do nothing else, at least talk to him. He does a lot of high-end cylinder head work and balancing, but has (I think) all the equipment in his shop to do the whole deal right there. Last time I was there he was finishing up a Donovan big block, blown.
Like I say, at least talk to him He is expensive, I suppose, but he does beautiful work.
Pat
Old 12-12-2006, 09:15 PM
Strummin
What kind of engine are you rebuilding? What are your expectations for the build?
Old 12-12-2006, 09:28 PM
I am going to disagree with the crate engine route. Only based on what I have read so far and if I am wrong correction is fine but I read that the internals of those fancy crate engines are filled with questionable parts. For example, cheaply cast mexican blocks (not talking about an older ford block), pistons from brazil, other parts made in various asian countries, etc. I don't know how true all that stuff is but I would prefer purchasing the parts on my own, knowing where they came from, etc. Also I would want something in writing from the person who machines the engine. Oh yea, if it does fail and its no fault of your own, make sure the agreement is for both labor and parts and not free labor-you pay for the parts. My father got burned by a local guy when they neglected to check the valves spring retainer to underside of rocker arm clearance. Took out two cylinders, some bearings, and either one or two rods. Its ultimately up to you though.
Old 12-12-2006, 09:55 PM
strummin67's Avatar
I'm not looking to race the car. I just want to be able to keep up with traffic.
Strummin
Onovakind did you sell your 283?
Old 12-12-2006, 10:00 PM
No. It's still sitting out in Vacaville.
Old 12-12-2006, 10:07 PM
BOBCRMAN@aol.com's Avatar
QuenchPiston. You haven't bought any aftermkt engine parts lately have you??
Heco en Mexico is on most newer GM castings. Timing components are all Asian. Stainless valves=Argentina or Isreal. Most all crank/rod forgings are from across the pond. Bearings=Isreal. Rings=Mexico. The list goes on and on. Just because it says Fed-Mogul on it or Speed Pro. If you read the fine print it was actually made FOR that co. and re-boxed.
It is now a WORLD mkt. not like the old days
Old 12-12-2006, 10:28 PM
strummin67's Avatar
onovakind. I sent you a PM last week. Did you get it?
Strummin
setting points on sb chevy frackster66 Electrical 23 01-07-2014 06:50 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 11:00 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 11:12 AM
Engine Choice, Please Help savman1 Engine 1 01-12-2006 10:36 PM
rebuilding specs for olds engine Blob Engine 2 11-30-2004 09:03 PM
