Not to sound like a smart ***....but....fully depends on whether you have the correct tools to do the job, whether you have another body around to help out with hard to reach bolts, and how hard you work....etc.....
I'm sure there is shop owners on the site who can give you a good estimate on the time....I would guess no time at all , I'm disabled with a spine injury and I pulled and placed a motor in my elkie with the help of my wife in a little over 4 days and that is starting and stopping...back, legs and arms really limited my work....good luck
Small world, I'm 69 years old, pulled a TH350 and installed a TH400 in my '72 in four hours by myself just yesterday, I felt like I dogged it.
If I had help removing the hood I believe I could have had the 454 out in another hour and a half at most, including dropping the headers and draining coolant; reinstalling would go about the same.
I would think 5-6 hours should be enough.
If you have to transfer oil pan, rocker covers manifolds etc, then add another couple hours. Should be a done deal by days end.
Not like it is a 5.4 liter ford
Back in the hotrod shop days this used to be a one day job assuming the replacement motor was the same vintage. Headers and non stock items were cost adders. AC, power brakes, power steering and manual or auto Trans were other factors. AC is a Problem if it still has freon 12.
The shop should be able to give a flat rate plus adders. I'd surely get an itemized quote. Don't be afraid to ask about over runs and unforeseen problems. 10 % is usually allowed.
This one is not too difficult but the killer can be stuck bolts and nuts especially exhaust headers or manifolds.
We used to give an itemized quote and add a cushion " not to exceed". It always looked good if we came out under quote. I still do this today.
Depends on several factors that you haven't mentioned yet. Does the car run? How long has it been since the motor was removed (time and miles)? Was/is the motor installed correctly (implying that no torches, cut off wheels or die grinders will be needed)? Is this a show car with an immaculate exterior and engine bay detail?
With the answers to those questions in mind, if you are asking for a professional job by a quality guy/shop with a warranty then $800 wouldn't be too much. Add on as necessary.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
