engine removale - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2011, 12:17 PM
engine removale
trying to remove motor from a 1996 blazer 4by4 took 3 bolts out of flywheel and bolts out of the bellhousing. engine still wont split from the transmission . any help is appreciated
Old 04-17-2011, 12:29 PM
motor mount bolts out? should be 6 bell housing bolts, raise motor ,block trans
and shake it a little or pry between converter and flywheel
Old 04-17-2011, 12:33 PM
75chev4x4's Avatar
how bout the motorm ount bolts? Manual or auto trans? The manual tranny can be hard to split sometimes. As you lift the motor rock it side to side and pull, just make sure all your bolts are out.
Old 04-17-2011, 12:34 PM
75chev4x4's Avatar
Sorry dg, beat me to it.
Old 04-17-2011, 12:52 PM
thank u
cinderella here . 6 bell bolts out 2 motor mount bolts out 1motor mount out and 3 flywheel bolt out manual trans will try prying between the the flywheel and tourque converter starter hole is small thanks for the help
Old 04-17-2011, 01:16 PM
engine removal
is this a manual or auto? manual trans don't have a torque converter, just a flywheel that is thicker with a clutch bolted to it. when the bellhousing splits from the engine, the trans will just pull out of the clutch, unless there has been some damage to the clutch hub or trans input shaft. if it is an auto, make sure all the torque converter bolts are out, push the torque converter back into the trans to be sure. then make sure all the bellhousing bolts are out. sometimes they can be stuck on the 2 big alignment dowels in the back of the engine. try just giving it a little pry in that area. othewrwise, lift the engine just a bit, with a blocking system under the trans, and then rok things some while you pry.
dsraven
Old 04-17-2011, 05:27 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Just 3 flywheel bolts? there's your problem.
Cole
Old 04-17-2011, 06:58 PM
eloc431962's Avatar
Wiki Edits: 37
Seriously why are you removing the flywheel bolts to pull the engine anyway ?
And your sure you have all the bell-housing bolts removed ?
And which transmission is it anyway manual or auto you say manual but you talk about the converter ?
Cole
Old 04-17-2011, 07:01 PM
maybe your not pulling hard enough cindi
the dowel pins hang up good just needs a wiggle make sure all the harware is out for sure before getting aggressive.
pushing the clutch a few times with the bolts out helps sometimes
Old 04-17-2011, 10:06 PM
CJ_1080's Avatar
known to do dumb stuff!!
Cole
That's what I'm thinking! At least the V8's around that year (my 96 350) had 6 bolts from flywheel to torque converter!
Old 04-17-2011, 10:46 PM
busted knuckles
my 78' 400 small block and my 88' 350 only had three...
Old 04-18-2011, 05:37 AM
CJ_1080's Avatar
All the older ones I've come accross only had three as well. But both of my 1996 Chevy's with the 350 (5.7 L) had 6!
Old 04-18-2011, 07:15 AM
motor removal
just for giggles, is this an automatic or a standard? automatics have a flexplate, skinny thing, like the thickness of a quarter, with a toothed ring welded onto the outside perimter. standards have a flywheel, much thicker like about 1/2 to 3/4 of an inch thick.the dead giveaway is that the standard trans vehicles have an extra pedal hanging under the dash. ha ha. (hey joking here, but nobody has made that little point yet, standard or auto?)
if it is a standard, there will be no torque converter bolts. if it is a standard you don't have to remove any flywheel bolts, the transmission input shaft will slip right out of the clutch, unless there is a previous clutch problem and the shaft is hung up on exploded parts. the clutch and flywheel stay on the engine until after the engine is removed.
if it is an automatic, look through the starter hole (if there is no inspection pan under the front of the trans) and make a crayon or chalk mark at the first torque converter hole bolt you come to.turn the engine over by hand and remove all the torque converter bolts as you go. when you find yourself back at the crayon mark, waah-laah, they are all out. even if they were still all in, the engine would still split from the trans, it is just that the torque convereter would be still attached to the flexplate.
it sounds like you have some alignment dowels that are giving you grief. if you have made sure that all the bolts are out and motor mounts and stuff are all undone, jack it up a little and pry the sucker apart. you could try some penetrating fluid on those dowels and leave it for awhile to work. you could try a hammer and punch on the dowels (from the back side, like you are trying to push them out the frontside, just enough to loosen them up), you could try the screwdriver and hammer trick between the two housings at the spot where the dowels are located, that sometimes helps to loosen the dowels. just don't crack the housings. if all the bolts are out., there isn't much left that can hold it up except the dowels or maybe a siezed pilot bearing in the end of the crank, the trans input shaft would maybe be stuck in that bearing.if that is the case there isn't much you can do about it except use a prybar. if the clutch linkage is still hooked up, try stepping on the clutch pedal, sometimes that will force it apart.
good luck, and some clarification on auto or standard would definately help us help you. if it is a standard, stop talking automatic terminology. not trying to be grumpy, just saying.
dsraven
Old 04-18-2011, 05:13 PM
eloc431962's Avatar
Wiki Edits: 37
Cole
That's exactly what i am trying to find out, "MANUAL" OR "AUTOMATIC" this is a need to know thing to help there are usually three converter bolts but usually 6 flywheel bolts and as stated you don't have to remove the flywheel bolt's to remove the transmission.
Cole
Old 04-18-2011, 05:52 PM
manual or auto
ok Cole,
listen, there lots of guys, including myself, who call the flexplate a flywheel sometimes. maybe that is leading you into confusion.guys will call the flexplate bolts the flywheel bolts or vice versa. the thing we need to know, to help you out, is if the transmission is an automatic or a standard. do you have a clutch pedal in the car or not. if you have a clutch then it is a standard transmission, a stick shift, a manual shift. it will have a flywheel not a flexplate. if it is an automatic, then obviously there is no freakin clutch pedal, and there will be a little indicator that says park, neutral reverse etc etc. get that info and we can go from there.
now if it turns out that it is an automatic. then do the thing with the crayon or chalk or whatever so you know you have removed all the bolts that hold the torque converter to the flexplate, that big doughnut shaped thing behind the flexplate. when all the torque converter bolts are undone slide the torque converter back into the trans as far as it will go, maybe 1/2 an inch if you are lucky, but definatley will move backwards away from the engine. now you know it ios for sure disconnected from the flexplate.now, if all the rest of the bolts are undone on the bellhousing and engine mounts etc, you can try to seperate the engine and trans.
if it is a standard, remove all the bellhousing bolts and engine mount bolts and seperate the engine from the trans, it should slip apart easily when the two parts are finally disconnected.
let us know how it turns out,
dsraven
Emissions removale. trubble Engine 15 04-12-2011 11:13 AM
350 Crate Engine: Loud humming sound after engine warms up sofa1515 Engine 2 01-11-2010 06:48 PM
Engine Help. Engine Turns over Hard, like siezed yet runs awsome. Merle9069 Engine 3 10-05-2008 06:38 PM
I need engine mount bracket ideas 1930 chevy with 302 boss engine. Riley Engine 3 07-25-2008 07:29 AM
Rust removale and paint before engine 72 Z28 Body - Exterior 2 10-20-2006 09:27 AM
