Engine rings - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-10-2005, 05:53 AM
Engine rings
I have just overhauled a 327 small block. My number 3 cylinder is pushing oil through my intake and my spark plug has oil around it. I was told that I probably was running too rich of a fuel mixture. I bought a new carburetor and still have the problem. I ran a compression check and all cylinders and it ran good compression. If the ring is ruined and I must replace them I would like to put something better then the chrome molly rings that I had in it. . The last time that I overhauled it the chrome molly was wore off the rings. I was thinking of perfect circle rings.
Old 10-10-2005, 08:55 AM
NorthStar's Avatar
Possible that the intake gasket is not sealing.
Moly rings are as good as youre going to find.
If youre wearing out the rings maybe the cylinder wall finish is not right or its ingesting dirt.
53 Packard Clipper Engine Swap? 53packard Engine 16 07-06-2010 04:32 PM
Rebuilt Engine Squeaking, Driving me Nuts! BH69Camaro Engine 24 04-22-2005 08:51 PM
engine vibration / harmonic balancer briansansone Engine 4 11-01-2004 09:29 PM
327 question adam15425 Engine 80 10-13-2004 09:22 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
