Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine run on
Thread: Engine run on
Old 05-18-2012, 09:06 AM
S10 Racer's Avatar
S10 Racer S10 Racer is offline
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Originally Posted by Greg T
To correct what S10 Racer said, your timing may need to be ADVANCED. If the initial timing is too retarded you'll have to open the throttle blades to maintain idle speed. Advancing the initial timing will allow you to close the throttle blades and still maintain the proper idle speed. You may have to limit your total mechanical advance, but I would start by setting the initial timing at about 18* or so and see what happens. As you do this, set your idle speed back down to about 750 RPM.
Thanks for correcting me, I had a brain fart
