Engine run on - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2012, 10:35 AM
Engine run on
Hey guys i'v built a 383 stroker 10.82 to 1 compression the car is talking to me when I shut it down. the timing is set correct and I'm running 94 octane someone told me if I used a colder plug it my correct the issue.
Your thoughts would be appreciated thumper 33
Old 05-17-2012, 10:58 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
It could be a few things so I suggest trying each one seperately and see if it helps before going to the next. Not necessarily in this order.
1. Carb fuel mixture needs adjusted
2. Idle is set too high. Try idle at 650-700
3. Timing may need retarded
4. Too high operating temp.
5. Gasoline containing alcohol
6. Spark plugs too hot
There are other reasons for run-on such as high carbon deposits in the combustion chambers. Sharp edges in machining processes can also cause run-on because they can cause "hot spot" so these should have been smoothed out during the rebuild.
What carb are you using and what temperature does the motor run?
Old 05-17-2012, 11:18 AM
The carb is the 650 mighty demon and at this time I have no temp gauge.
Thanks for the info I'll start at the top of the list and work my way down
I appreciate your thoughts
Old 05-17-2012, 09:07 PM
Another question for u I have a comp cam reverse grind 488/465 383 stroker what should my timing be set at and advanced timing be.
Thanks thumper 33
Old 05-17-2012, 09:34 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
To expand on S10 Racers post:
Which cylinder heads do you have?
What exactly is your idle timing?
How was it set?
Do you have the correct timing tab for the balancer?
Which spark plug are you using?
What is your idle speed?
Old 05-17-2012, 11:27 PM
Greg T's Avatar
www.krusinklassics.net
To correct what S10 Racer said, your timing may need to be ADVANCED. If the initial timing is too retarded you'll have to open the throttle blades to maintain idle speed. Advancing the initial timing will allow you to close the throttle blades and still maintain the proper idle speed. You may have to limit your total mechanical advance, but I would start by setting the initial timing at about 18* or so and see what happens. As you do this, set your idle speed back down to about 750 RPM.
Old 05-18-2012, 10:06 AM
S10 Racer's Avatar
Thanks for correcting me, I had a brain fart
Old 05-18-2012, 01:24 PM
Engine run on
How much water should I use if I was going to try to get rid of the carbon.
Thanks thumper 33
Old 05-18-2012, 01:38 PM
Blazin72's Avatar
Wiki Edits: 19
If you just rebuilt the engine there should very little, if any carbon buildup...
Have you addressed any of the other issues previously suggested in this thread?
Old 05-18-2012, 01:46 PM
I bought it off a friend the motor was built about 5 or 6 years ago my first thread on this topic was incorrect my bad sorry.
Thanks thumper 33
Old 05-18-2012, 04:23 PM
Blazin72's Avatar
Wiki Edits: 19
Ok.... You still haven't said whether or not you addressed any of the suggestions/questions posted here. In
Old 05-18-2012, 04:41 PM
Tomorrow I'm going to start from the top of the list and work my way down I'll re post some time tomorrow.
Thanks for all of the suggestions
Old 05-27-2012, 06:46 PM
Hey guys with the idle turned down to 650 up 700 the run on goes away the other issue I have is it bumps back up to 900 to 1000 any ideas what Taft is from the carb is 650 mighty demon.
Thanks thumper 33
Engine run on F150fatman Engine 19 08-09-2006 01:30 PM
engine run-on solidaxel Engine 17 07-03-2006 07:23 PM
engine run-on joe svoboda Hotrodders' Lounge 17 06-09-2004 08:58 PM
How much does it run to get an engine dynoed? elukas Engine 6 11-25-2003 10:03 AM
engine run-on 72HeavyChevy Engine 30 02-20-2003 04:12 PM
