Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine Run-On: 400 Tri-Power
Old 09-29-2012, 12:32 PM
Thumpin455's Avatar
Thumpin455 Thumpin455 is offline
Ask me about Ethanol
Last journal entry: 65 GTO
Yep, need to know what heads and pistons you are running to get 9.5:1. The differences in heads that will fit a 389/400 can make it ping or run on easily. Can you tell us what the number is cast into the center exhaust ports, if there is one there? Need to start somewhere, might as well be with the combination you have.
