Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine run on need help fast!
Old 09-20-2012, 06:30 PM
123pugsy's Avatar
123pugsy 123pugsy is offline
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Originally Posted by elcaminodragster View Post
Could the diode be bad or is the fault in my ignition switch?
Get your test light out and check if the ignition switch is indeed cutting the power or not.
