Engine running to cool - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2013, 01:30 AM
I am a new user. I know this probably has been brought up before, I looked at similar posts but nothing that answers my problem. I purchased a 74 Nova but the engine is a 77 305, not sure why the previous owner picked that engine. It originally had a 160 thermostat and had no problems, I decided to go with a 195 and I tested it before intalling it and it opened fine, now the engine will only heat up to 170 and I also checked to see if the radiator was flowing just in case the temp guage was not reading correctly and it appears to be fine. I have never come across this problem before, any help would greatly be appreciated.
Old 04-11-2013, 06:33 AM
bondo's Avatar
Ayuh,... Welcome Aboard,.... Is it gettin' to 170 runnin' down the road, or runnin' in the driveway,..??
Old 04-11-2013, 11:16 AM
Richiehd's Avatar
JS-70
and where is your temp sender located?
Old 04-11-2013, 11:57 AM
It gets to 170 in the driveway and just shy of 180 on the road. The temp sender was tried on the block and the manifold but the temp was only a couple of degrees different, it is currently in the intake.
Engine running too cool...totally baffled! Hotrodder78 Engine 18 02-11-2013 07:29 PM
Very cool video of Don Garlits running his "new" rail on a friggin drive way! MARTINSR Hotrodders' Lounge 5 10-09-2011 02:38 PM
Engine running to cool Mertz Engine 2 06-11-2010 11:46 AM
Stroker running too cool? bkcraun Engine 6 10-22-2006 12:02 AM
Car Running too cool???? Hollywooding Engine 4 11-28-2003 07:38 PM
