engine running hot - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2013, 04:42 PM
engine running hot
just put a new mufflers on my truck it was running at 195 like it should but now its running 240
has new manifold gasket's on it I cot all the 02's out of it and plugged the pcv (line that runs from intake to manifold talked to one of the guys at the shop and he said that's fine it won't make it run hot
I did bust the old temp sender of and put a new one on it
has any one had this problem before or know what's going on with my truck
Old 05-20-2013, 05:24 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
Different sending unit could be giving a bogus reading. Is the sending unit the correct one for the gauge?
Old 05-20-2013, 05:37 PM
its the one they gave me at oreillys i didn't know there was a difference they didn't ask me
Old 05-20-2013, 06:31 PM
Richiehd's Avatar
JS-70
Sheesh! OReillys...........
Better find out if its the sender, it wont run 240 for long
Old 05-20-2013, 08:45 PM
no I talked to some one
and since its a 96 and I cut all the o2's off its giving me a false reading I took a cooking thermometer and stuck it down in the radiator and it only running 150 so I have to run a after market gauge on it so it will bypass the computer
Old 05-20-2013, 08:48 PM
some how the gauge is weird in two the stock gauge
Old 05-20-2013, 08:49 PM
wired in to the computer
Engine Running Too HOT 65malibuSS Engine 6 01-17-2011 11:10 AM
Engine running hot, help please jstnt430 Engine 5 06-15-2008 11:45 AM
Engine running hot ???? GREENTHING Engine 16 07-03-2003 09:06 AM
Engine Running Hot! quartet Engine 0 05-03-2003 06:39 PM
Engine running really hot!! zeeman19 Engine 18 11-25-2002 12:09 PM
