Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine running too cool...totally baffled!
Old 01-04-2008, 08:37 PM
Classix_Lover's Avatar
Classix_Lover Classix_Lover is offline
Music soothes the soul
Last journal entry: Wiring finished finally
Put the old therm. back in or just use the same brand you were using before, see if you have the same readings. I've gotten several bad thermostats from the box before and it may be possible that it has failed in the open position, not properly regulating coolant flow between the block and radiator, allowing things to be overly cool.
