Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine runs hot at highway speed.
Old 08-28-2009, 12:52 PM
dawg's Avatar
dawg dawg is offline
NAVY VETERAN
ya might try a lower T stat at 180 degrees.
if your running without a thermostat thats a big NO NO.
and without seeing your setup im guessing the fans dont have a full shroud?
also is the radiators front side sealed to prevent air from going around radiator instead of through it? (youll be suprized on how great it works)
is your rad cap good?
a 12 to 15 psi should help.
one last thing to check is lower radiator hose.
look at it when you goose throttle.
if the inner spring is missing or the rad hose isnt the reinforced type it will suck itself closed causing high temps.
cool flex hoses (corrigated tubes) are not the best thing btw they tend to break apart.
one last thing is belt tension on the water pump
