Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine runs like krap after valve lash adj. HELP!
Old 05-18-2004, 04:20 AM
roys63's Avatar
roys63 roys63 is offline
You made a spacer for your EGR? Are you sure you have no vacuum leakage between the two ports, or the valve is stuck? This can cause a massive Vacuum Leak.
