Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine runs like krap after valve lash adj. HELP!
Old 05-18-2004, 07:25 AM
Jag Daddy's Avatar
Jag Daddy Jag Daddy is offline
1969 Mustang Coupe Project Car
Last journal entry: New Project Mustang, From Jag Daddy to Stang Daddy
You made a spacer for your EGR? Are you sure you have no vacuum leakage between the two ports, or the valve is stuck? This can cause a massive Vacuum Leak.
Well it runs the same with or without the spacer so I would think it's not causing the problem. The valve was fine before that
Regards
Mark
