I changed to some new wires and now the engine won't even stay running ( i first changed just the #2 cylinder wire then all). I'm thinking there is a problem with the ign. module because it is pretty warm out today and is really sunny causing a lot of heat under the hood. Last night it was running ok and was idling ok even with the #2 cylinder arching. Is there a way I can check the module to see if it is bad?
