I had the module tested and it passed he checked 5 times. Under where the module is there is a white buildup like oxidation can this cause the engine to run rough or not at all? I'm going to check all the wires and connections under the cap, clean off the oxidation, put some new lithium grease under the module and put it back together to see what happens. I'll post once I do this as long as it doesn't rain today.
