Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine runs rough.
Old 09-09-2005, 01:16 PM
T-bucket23's Avatar
T-bucket23 T-bucket23 is offline
Wiki Edits: 26
Originally Posted by lt1bbody
I had the module tested and it passed he checked 5 times. Under where the module is there is a white buildup like oxidation can this cause the engine to run rough or not at all? I'm going to check all the wires and connections under the cap, clean off the oxidation, put some new lithium grease under the module and put it back together to see what happens. I'll post once I do this as long as it doesn't rain today.
That "white build up " is thermal transfer grease and is supposed to be there. It helps to cool the module while still alowing an elecrical connection. If you dont put some on the module and plate you will be replacing the module soon.
Dont use lithium graese, get the proper grease from the parts store or a Radio Shack, either should have it. It usually comes in a little syringe type applicator.
