Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine sbc combanation
  #17 (permalink)
Old 10-28-2012, 06:19 PM
wwilliams181's Avatar
wwilliams181 wwilliams181 is offline
I honestly think you will be fine with this cam. The problem most are talking about is that the Rpm range is narrowed and the loss of cylinder pressure due to the added overlap. That cam already has 5 deg. built in. I would install it straight up which would be an intake centerline of 102. If you ar a little high on compression.. this cam will work to your advantage when using pump gas. The upside to the sound is the throttle response. The head choice you are looking at will be fine. If you havent bought pistons yet.. i would tell you that this is one place you should spend your money.. i buy almost the lightest thing i can get. You will really gain here.
