Your choice of IFS kit. Free speech auction: win your choice of Mustang II IFS kit, donated by Progressive Automotive.
Retail value: $1,159.00
Current high bid: $100.00
Click here for details, or to place a bid.
All auction proceeds go to support the legal fund to defend against the frivolous lawsuit filed against us by Streetbeasts.
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 08-29-2002, 01:06 PM
Chevydude Chevydude is offline
Post Engine serial number
Hello, I have reently got my hands on a 3970010 engine. Have been trying to get info on engine serial number 17J11530JB without success. Anybody have any info on this or can tell me where to get it would be appreciated??? TNX
Old 08-29-2002, 01:38 PM
MHenricks MHenricks is offline
Post re: Engine serial number
Try Mortec.com, this is a pretty cool site.
Old 08-30-2002, 02:17 AM
I did dtry motec.com, but did not find any info on the pad serial number???? Any other ideas? Guess I could try GM?
Old 08-30-2002, 04:25 AM
awsum34's Avatar
awsum34 awsum34 is offline
What i found out about your motor. If it is correct. 17J1153JB
1- chevy
7- 1977
J- built in Janesville
11530- production sequence of VIN.
can't find anything on the JB. Normally the last letters tell what car it was in. might check and see if the JB is right.
I know the motor 3970010 was put into cars, trucks and vettes.
327 and 350 hp- 185 to 370, 2 and 4 bolt mains,
Old 08-30-2002, 05:07 AM
bildo95 bildo95 is offline
Got this from mortec.com
3970010....302.....69....4...Z-28 Camaro
3970010....327.....69....2...Trucks and industrial
3970010....350...69-80...2 or 4
Bill
Old 08-30-2002, 06:37 AM
tell_me_y_n tell_me_y_n is offline
Smile re: Engine serial number
I checked in my chiltons 1965to1972 book engine identification code letters JB= 1969 8cyl 396 cu.inc. type PG-powerglide transmission listed under Camaro engine identification only.in this book. A typical vehicle serial number when broken down. MFR body style year assyplant unit no. 1 5645 8 f 100025 sample for interpertation only. Good Luck
Old 08-30-2002, 06:51 AM
Mertz's Avatar
Mertz Mertz is offline
Check out this site; <a href="http://www.yearone.com/updatedsinglepages/Id_info/engine_id.htm" target="_blank">http://www.yearone.com/updatedsinglepages/Id_info/engine_id.htm</a> it shows your block number in the example but I have not found the breakdown of numbers. If nothing else it will frustrate you a little more.
I think your 17J11530 jb is a vin number not an engine code. If JB was in the engine code it would be a 1969 325hp 396 Camero with automatic trans DZ denotes 69 z28 Camero with 302
Found another site that says that 3970010 is a 69 302 or 69 thru 80 350 so I guess the only way to know for sure is the engine code as note on the site I gave you.
If 17J11530 is the vin than it is a 1977 chevy out of Janesville probably making it a 350. Don't you just love the research!
[ August 30, 2002: Message edited by: Mertz ]
[ August 30, 2002: Message edited by: Mertz ]</p>
Old 08-30-2002, 12:01 PM
slider in wa's Avatar
slider in wa slider in wa is offline
Slider in Wa.
Just wondering? is this the stamped no# on the right front shelf (passenger side) of the engine? It would be just below the head.( in front face of motor)
I thought i had a 68 302 untill i found and broke down the suffix code. Hope it helps. Let us all know what you find out will ya?
Slider in Wa.
Old 08-30-2002, 01:28 PM
Mertz's Avatar
I found this but pretty much the same stuff:
3970010 350 69 Corvette Late 69, 4 Bolt Main
3970010 302 69 Camaro Z/28, Late 69, 4 Bolt Main
3970010 350 69-79 Truck 2 & 4 Bolt Main
3970010 350 69-79 Pass, Chevelle, Camaro, Nova, Monte Carlo 2 & 4 Bolt Main
3970010 350 70 Corvette 300, 350, 370 HP Bolt Main
3970010 350 71 Corvette 270, 330 HP, 4 Bolt Main
3970010 350 72 Corvette 200, 225 HP, 4 Bolt Main
Need another set of numbers to identify for sure. 17J15300jb is to short for a vin number. Still looks like a 350 truck block to me.
Old 08-30-2002, 03:58 PM
I want to thank all of you for your inputs on this. Yes, it is a stamped number on the pad below the right side head. I will look at it closer to see if I made a mistake and let myou know what I find out. I am pretty sure it came out of a Chevy van which is long gone. Would be nice to know exactly what year it is. This engine supposedly has only 44,000 miles on it!!
Thanks again!!
Old 09-07-2002, 06:23 AM
Slider in Wa.
So chevdude, what do ya got for a motor? What did you find out?
Slider in Wa.
Old 10-29-2002, 02:53 PM
hot82chevy hot82chevy is offline
You can easily differentiate between a 302 and a 350. Just pull the pan and check the crank. The casting number will tell you the crank info and that combined with the block casting number will tell you about the engine.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
