engine setup angle - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2003, 07:03 AM
Post engine setup angle
I am building a kit car and are unsure of of the correct angle when mounting the engine. The motor mounts are bolted in and ajustable. I,ve been told to put a level on the carburetor mounting surface to get the correct set up angle but my intake manifold (GM Performance dual plane intake manifold, part number 12366573) has a slant to it. When it's level(Manifold/carburetor) the transmission tailshaft is slanted downward. Is this carburetor/maifold combination designed to slant down towards the front and do I use another part of the engine such as the valve covers to level the engine
Old 01-11-2003, 07:39 AM
aka Duke of URL
Arrow
[quote]Originally posted by carolinakid:
I am building a kit car and are unsure of of the correct angle when mounting the engine. I,ve been told to put a level on the carburetor mounting surface to get the correct set up angle but my intake manifold (GM Performance dual plane intake manifold, part number 12366573) has a slant to it. When it's level(Manifold/carburetor) the transmission tailshaft is slanted downward.<hr></blockquote>
The angle of the carburetor mounting pad is to insure level mounting for the carb and the fuel level in the bowls. When set properly, the trans will have a downward angle.
It is best to ascertain the correct angle (level) once all the weight is on the suspension and you have your desired trim level.
Old 01-11-2003, 08:24 AM
72 chevy's Avatar
Post
This might help What exactly are you building, ya gotta tell us! drive line phasing
[ January 11, 2003: Message edited by: 72 chevy ]</p>
