Which engine should I put in - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-08-2012, 03:05 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
Not a turbo guy,but what about the bottom end at 500hp and just logical deduction leads me to think exponentially as the turbo spins up it would require a better octane gas.As I said not being a turbo guy I don't know where that requirement for better gas would be as apposed to the amount of boost.
More output from a engine is more heat,thus forged pistons,ring gap's set for turbo/supercharger,upgraded rods,and some sort of upgrade for a crank just in case the one time the car hooked hard,would all be in play I would think.
  #17 (permalink)
Old 11-08-2012, 04:04 PM
Banned
It depends on the cam, compression, intercooling, and the turbo used. The turbo used is often overlooked as most people don't understand how complex they are.
With a good aftermarket turbo that is properly sized moderate compression and boost and a mild cam, and decent intercooling there's no reason a stock short block couldn't handle it. You shouldn't have any need to spin over 6,000rpm either, and RPM is much harder on an engine than boost.
  #18 (permalink)
Old 11-08-2012, 04:11 PM
hcompton's Avatar
Old & Furious
Yeah bottom end is not going to take 500 for very long. I have seen it done and last a while but i have also seen them pop on the dyno. So its always a gamble to not upgrade all the weak point. But many people have good combos that will live on the street and make 400-450ish. I am not a ford guy so cant really help. Maybe someone will jump on and help with what you can do before you go into the block.
You will need premium with any supercharger or turbo upgrade and without pistons or some other changes to low static compression its going to knock before it hits 500. 5 or 6 psi is possible with the stock block and premium gas in most areas and weather conditons. You dont want to build something so border line its not going to drive on 100 degree day in the summer or start when its 15 below out in the winter.
You can buy super charger kits from vortech and paxton that will meet your needs and they have great recommendations for install and other parts that will be needed to make it work correctly. I can do turbos for next to nothing but really the supercharger kits a so easy and saves so much time. Just to bolt it on and be rocking fast the next day. Turbos are a little more tuning and playing with the setup. I think you can just buy a stage II or stage III super charger kit that will give you the power you are looking for. I bet they even sell one that is a bolt on for the stock engine and just need injectors and fuel pump updates. May not hit the full 500 but you can get a lot of jump and run out of the stock engine with boost.
If you want to go bat ***** just google kenne bell.
Kenne Bell Homepage
  #19 (permalink)
Old 11-08-2012, 04:20 PM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by Project mustang View Post
This is my first project car and I'm wanting to put in a new and better engine in it than what is in it now. It is a 95 mustang with the 302 boss engine and I have a brand new t5 transmission in it. The engine runs fine right now but I'm wanting to know what would the best engine be to put in it for more power but at the same time be able to have a good cruise in it every now and then. Any help would be great because I'm not that good with engines.
Your plan is flawed from the beginning. The T5 is barely adequate with a stock motor, much less 500 hp. And you're starting at the wrong end of the car.
  #20 (permalink)
Old 11-08-2012, 06:27 PM
vinniekq2's Avatar
I dont think you should start with the engine.First thing to do is the brakes,suspension.Depending on how serious you upgrade the brakes,new wheels might be in order and of course tires. Traction control devices and posi traction as required.
Stage II would be the transmission/engine trans plant,including exhaust upgrades for application.
  #21 (permalink)
Old 11-09-2012, 07:58 AM
I'm not starting with the engine. It needed a new transmission so it could be driven around. I haven't touched the engine or transmission since then.
  #22 (permalink)
Old 11-09-2012, 08:36 AM
I hope you have fab skills. A friend of mine built a twin turbo 347 for his mustang using a fair amount of junkyard parts. He eventually got around the 500hp mark. Auto trans, refurbished/modified diesel truck intercooler, aftermarket heads and some OEM turbos which he later swapped to a big single diesel truck turbo. You could grab 2 turbos for a 2.5L or thereabouts engine, and make it work with what you've got. It'd be fun to drive. Its not the RIGHT way; but its been done 100 times before. With respect to the ecm; there are some backyard tricks which arent efficient or precise, but work.
Every kid says he wants 500hp. Thats nice; but the quickest way to get a kick in the butt is to change the rear gear in your current car and ditch the T5 for a TKO. Add in a hotrod muffler and just drive and enjoy it. If its your only car, adding things like turbos or superchargers and pulling the motor for a rebuild, will quickly get old...you'll end up with a half finished car and probably sell it.
they say you can put an engine on anything.... matt167 Off-Topic 9 08-06-2009 05:39 AM
If you could build any engine, what would it be? and what would yo put it in? charger528 Hotrodders' Lounge 32 11-02-2007 08:37 AM
what engine to put in a 71 nova backyard71nova Engine 44 09-23-2006 12:27 PM
best engine to put in a s 10 bigdaddy5884 Hotrodding Basics 31 10-16-2004 05:13 PM
I want to put 7 grand into my engine neil madsen Engine 35 02-28-2003 07:07 PM
