Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine shutting down at random.
Old 03-18-2012, 10:55 AM
66GMC's Avatar
66GMC 66GMC is offline
Get in, sit down, hang on
Last journal entry: Cab Removal
When the engine dies, refuses to re-start ... is there any spark?
Is this is a contact point distributor? (or electronic)
If so, check the points for gap, pitting, and color.
If the points are blue ... it's because they are getting too much voltage.
Check the coil and see if it says "Use with external resistor" (or internal resistance)
