Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine shutting down at random.
Old 03-18-2012, 06:43 PM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
Dime to a donut...... when they put in the new 350 they just hacked a wire to the run position on the ing switch....... which is most likely loose/bad etc...... Pull the switch and see if you have what I've described......... That's exactly what was wrong with my 67, I ran a new wire, not thru the fire wall connector, put in a proper splice and it fixed mine.
