Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine shutting down at random.
Old 03-18-2012, 06:56 PM
cloned1973 cloned1973 is offline
They had a new wire ( I say new but I mean a wire with plastic insulation) going to the coil, that was about two feet long. That was tied in to the old resistor wire, that old wire looked like cloth, or some other material than the normal plastic. What I do not under stand is the same wire going to the coil someone put in a splice that goes to the starter. I'm not sure if that is normal.
In another words it goes from bulkhead to resistor wire, spliced in is the newer coil wire, but before the newer wire it goes to the coil it does another splice, that branch goes to the starter, a thick wire. I'm getting confused just writing this.
