Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine shutting down at random.
Old 03-18-2012, 07:29 PM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
If you are running an HEI, you don't need the resistance wire or the wire from the starter "I" terminal. So...... I would run a new wire from the HEI thru the fire wall (no splice, no bulk head connector) to the run/start position on the ing switch. Eliminate all the old wires and your troubles.
