Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine shutting down at random.
Old 03-20-2012, 04:17 PM
cloned1973 cloned1973 is offline
Question, Im looking at my electrical wires while Im waiting for my ignition switch. It seems like the starter wire from the battery may be grounding out on the header. I removed the wire and saw a bare spot on the wire (it was resting on the header) and what looks like the remnants of a arc on the header. Can that cause the motor so suddenly stall out?
Also Is it normal to have Three wires going to starter?
1, Starter wire from battery 2, A wire that is attatched to the old resistor wire
3, What looks like a little larger purple wire from the bulkhead.
